2 Hose Fittings On Mikuni Carb? HUGE PIC
cody89
I have a 1991 YZ 125 engine and has the stock original carb which is a Mikuni TM. I am not sure what the bottom feed is on the carb. The big one I am going to imagine is for fuel to go into the carb but I am not sure what the bottom one does.
http://i.imgur.com/GNxnd7G.jpg
Also, I noticed that this fuel line is bigger then the fuel line i have for the kart. would it be fine if I took the bigger hose and ran it from the pump to the carb but kept all the other fuel lines the smaller size?(tank to pump, pump to tank(return)).
Oxymoron
Newbesque builder.
Maryland
It's probably for the automatic oiler. You can just plug it off if you're just going to run premix.
anderkart
Surprise Arizona USA
