1st Manco rebuild
Old dingo fan
Sacramento CA
I bought a Mango Dingo @ yard sale in pieces for $20 4 years ago. I finally got around to restoring. (Very proud old man). Once all together, noticed on 1st ride. Rear wheel wobbles. Can't find 8" hex hub wheel anywhere. Does anyone have a used one for sale or now best way to repair.:mad2::mad2:
Old dingo fan
Sacramento CA
Previous owner sideswiped the curb. I replace the hex axle, bearings, hangers, chain, CVT 30 series, all four tires and smoke, engine and stripped and painted. Runs very well, just nervous about the wobbly wheel. Seems to be slightly bent at the hex hub do to already replaced axle
Karttekk
Elizabeth, PA
Any way to fasten a straight edge near the inside of the wheel then rotate it to see if it's the wheel or the hub?
bthompson224
DFW
There was another thread someone looking for that same wheel. He was able to luck out and find a member that had one. It appears there is no retail outlet that has them. If it is the wheel and cannot be repaired, it was suggested to get a hex axle hub then you can use a regular 4 lug wheel. Be sure it's the wheel first, excellent suggestion already to help diagnose.
http://www.diygokarts.com/vb/showthread.php?t=40096
Old dingo fan
Sacramento CA
Thanks for the link. I did notice that in my search but was trying to avoid if possible due to the money I already spent. On a good note, I put 18in PVC sleeves over the wheels and it's a great drift in cart. LOL
---------- Post added at 11:16 AM ---------- Previous post was at 11:15 AM ----------
New to this and would love to post pictures but don't know how. Help
Lol, did you bash in your fuel tank so it would fit behind the seat? :eek:
You can also unscrew the three screws holding the recoil starter on the blower shroud and “clock it” counterclockwise so the starter handle is pointing to the rear and reinstall the screws. Helps tremendously.
The photo of your red wheel is trippy as heck. It looks as distorted as a Salvador Dali painting...:D
Guapo613
Shasta County, California
I was looking for a spare 8" hex wheel myself. I ended up giving away my only 8" hex wheel to another member of this forum.
Your solution is to buy a pair of 7/8" hex hubs in the 4x4 pattern that Go Powersports carries and a set of 8" wheels from whoever (BMI, OMB, GPS, Go Karts USA, etrailer.com, etc).
