does this look right to anyone????
It is what it is.
This clutch will not be a problem nor will it's distance outward be a problem for crankshaft. Something else will break
long before pto does as long as everything else is correct. Make sure chain is properly adjusted. Should never be tight at any point during it's rotation.
I prefer the "straight through bore" clutches, more commonly known as "Bi-directional". This type of clutch is somewhat more adjustable as to where it can sit on pto depending on how long it is.
Both types of clutches have advantages as well as dis-advantages.
