19mm (3/4") Bore Clutch Problem
VirtualGod
Hi guys I found few clutches on eBay but they don't have a keyway?
The crankshaft has keyway on it but clutches doesn't. How can I install a straight bore clutch to a crankshaft that which has a keyway?
anickode
S.E. Michigan
Never seen a smooth bore clutch before. It would be kind of pointless.
If you're going by the picture of the sprocket side of the clutch, you won't see the keyway. It's on the opposite side.
David Ham
Melbourne
they do sell keyless clutches for some minibikes, but you should be able to find keyed clutches pretty easy
buy a maxtorque SS (the go to clutch anyways)
you might not see the keyway on the picture
(you can only see it from the backside.. the front is indeed smooth)
but it'll have one.
They are pretty good... You can also get different spring strengths that can be used(mixed colours) to change the engagement point to where you want it.
VirtualGod
Does it have? If it has i will buy it.
---------- Post added at 04:33 PM ---------- Previous post was at 04:26 PM ----------
But I don't think this one has a keyway?
No it doesn't have a keyway..... It has an integral key.
The keyway is present on the shaft, which this is mounted to engage with said key...
