Michaelsurfs
Jet n Spray 22hp 4stroke
In the process of installing a 22hp Predator 670cc into my 11' jetboat. I concluded using a torque converter setup would be better than a tensioner as i had intended. I'm enjoying seeing the mods and repairs you guys have done using torque converters. Thank you for inspiring me to use one. I was going for double the motor rpm at the impeller . I do go slower in the ocean due to chop and swell so low speed better torque will work. I'm using a series 40 and will try attaching the driven pulley to impeller shaft and bypass using a chain. I'll keep you posted if any one is interested. I wanted a low maintenance 4 stroke and don't go over 25 or 30 anyway so more hp is not real necessary. I have a 650 and a 700 waverunners so if i need speed I'll use one of them.
