1950 Schwinn
chain
Plymouth, Ma
Im building up a Schwinn Panther, The frame is a 1950
Forks are felt abrahams with the stem modded for a 1 inch schwinn neck.
sturmey archer 90 mm dymo hub in front motobecane.drum hub in rear.
wheels are going to be 19;incch moped with 11 ga. Spokes.
Here is where I need some help. The motor is a kawasaki fa130d as19 from a jd edger.
Ive done the ports -took out the govenor- going to the eyebrows- got rid of the diaphram carb and am going to use a flo jet
and plan on a billet jr dragster flywheel. Im not too sure about doing anything else becuase i cant find any internal performance parts. Looking for advice/help/ or leads to parts. Anyone makencustom parts rods?
What sort of drivetrain/gearing/clutch etc are you going to use? With 19" tyres you are going to have to gear low. Are you using a jackshaft? Are you sure that the engine can handle being mounted at that angle. Usually engines are good to about 20 degrees
chain
Plymouth, Ma
Thanks for the interest. Im going to be using 19 inch rims which should give me a 25 inch profile. Im going to use a drivenset up similar to a whizzer with a final belt drive. Im not sure yet if I will be usjng a cent. clutch or the slip style wbich is just slipping belts .
chain
Plymouth, Ma
So some things came up for a while and the toy had to go on hold. But I ended up scrapping the Kawasaki engine and going with a 3 hp Briggs I/C. Carb is a 5 hp flo - jet ( probably need to get something bigger but I like the stock look) had DynoCams weld up and put the 94ss grind on a factory compression release 3 hp cam, exhaust springs both in and out, 5 hp lifters, cut head,spring pockets, billet flywheel, analog tach, my seat came it's the black one on the right, still have a bunch of stuff to do but it's getting there.
chain
Plymouth, Ma
Special wide cranks for clearance, need to keep the pedals so it's street legal.
