BeaterofAincrad
2018 Build-Off Contestant
I'm trying to fix a 160cc Honda push mower for a client. I did a light "spring cleaning" on it about a month ago. Anyways they lent it to someone and when they got it back it wouldn't start so he brought it to me to see if I could fix it.
The first thing I noticed was that the blade was bent EXTREMELY badly, I haven't bent it back yet because I want to get it running first.
I cleaned the carb, still no luck.
I checked for spark, have it(blue).
Gas(good gas) is getting to the cylinder.
There was some carbon on the plug so I cleaned it up. I was getting a black liquid(gas/oil mix?) on the plug itself.
I looked inside the cylinder through the plug hole and noticed some carbon on the head and I can't remember if there was any on the walls.
I checked the flywheel key and it doesn't seem to be sheared.
I removed the OHV cover to see if anything was wrong in there and nothing seemed off, other than the valve lash was atleast .015. I didn't mess with it because I wasn't sure if the valve lash(of .004) was different for this engine
I checked oil level and it's good and while taking the OHV cover off it did NOT seem like there was gas in the oil.
I also attempted to reset the governor, but it didn't need it.
I will get one fire every now and then but it doesn't seem to try to continue.
At this point in my opinion it's either the valve lash, something I'm overlooking, or something I haven't experienced/heard of before. My father(not a mechanic but does have a good amount of knowledge/experience with small engines and such) doesn't think it's the valves(though he's never even considered messing with them on any small engine).
Any advice would be greatly appreciated. The picture wasn't taken from the best angle but here it is anyways.
Sent from my iPod touch using Tapatalk
