16 hp duromax
KartFab
Dallas, TX
A new one if you don't want to mess with cleaning it out/rebuilding it? Carbs don't go bad, they just need to be taken apart and cleaned, sometimes seals/gaskets need to be replaced.
rmm727
Brookville, PA
What do you hate about it. No adjustment screws? Its not that hard to jet these. A cheap drill bit set and a little time and you'll be good to go.
Arkyhunter
Benton Ar.
Well mostly i hate the plastic linkage and parts and I have to have a strong spring to bring it back to idle.It still works ok just like a better carb. I look at some on ebay but I dont no how to choose one do I go by cubic inch etc ?
Arkyhunter
fowler
Bullsbrook West Aus
U can use pretty much any carb of a similar displacement engine
Maybe try a Honda carb
If u want a straight bolt on then your only option is anoughter duromax
Maybe an older one
solomon
ca
I try to match up carburetors with a the samesize or slightly larger ID. Only go with a larger diameter Id if your going to port to match. You will have to make a custom intake manifold to marry the new style carb to the block
exenos
Project Nut
Arkyhunter
Loosen the nut on the throttle arm.
Arkyhunter
Benton Ar.
I did that first with no luck..its the linkage thats to weak,I found a guy on here uses a mikuni 33mm carb on his 16hp.
