150cc vertical lawnmover engine
DubstepEu
Manchester UK
I have 150cc vertical engine and need to make it horizontal what is the best way?
i had an idea of using an angle grinder gearbox would this work?:confused:
crazyman
Yorkville Il
What about keeping it simple with belts and pulleys?
sexyvicta
some old mowers use a twisted belt. Dunno how well that actually works. Otherwise you could use belt drive to a lawnmower gearbox/diff
B.M.800
TheBeal.
Central PA
i have heard the belt and pulley system work but ive also heard that you burn through more rubber belts than you do tyres!
They also moved alot slower than most of us would like. :roflol:
Belts work fine for the right application, I dont think a balt setup like Crazyman diddled up would be efficient, it may take up quite a bit of space.
Then again, perhaps it couls be made to work. Still, I dont think it would be good if you wanted any sort of speed from it.
My $.2...
dmaznic
dmaznic
Toronto
use a snowblower transmission or riding lawnmower transmission, In all honesty, just invest in a horizontal shaft engine. Now they are found for $150 easily, much cheaper if used.
By reducing the size of the pulley on the transmission you instantly increase your speed; those things use some big a$$ pulleys.
You have the right idea with the angle grinder gearbox; see if you can get hold of a larger right angle gearbox to suit you application
dmaznic
dmaznic
Toronto
word of caution with angle grinders, they are made for high speed, very low torque applications. if you put it even into a 2-stroke mini bike with a 3yr old riding it, you better have some really low gearing. also, think about how you will mount it/transfer the torque. on that note, see how much money and more importantly TIME you would like to spend on this project :D
you are more than welcome to experiment, we would all love to know how it goes and wish you luck!!!
r_chez_08
Should be in the shop...
Cornwall, UK
These people have a load of RA gear boxes. They are quite pricy though. Maybe mc master has some bevel gears and you could build an oil filled housing?
