150cc go kart wont idle
tawas23
I just go a Carbine 150cc go cart and cleaned the carb just bought this and cant get it to idle its runs ans starts fine only when gas pedal is pressed its has emissions and some lines were off so fixed that but need help to unsure all carb lines and emissions are correct or remove emissions if necessary has a kelin carb can someone send a pics of line routing and I did remove air/fuel plug so it can be adjusted just wont idle thanks in advance ..I adjusted carb 2 1/2 out from all the way in to 2 1/2 turns out is that right on a kelin I do have knowledge on the gy6 scoots but this has a different carb its is a cvt carb has the bigger cdi box also DC I believe ..plug has 4 the other only 1 wire on cdi box,, thinking valves might be causing issue as this is common on the scoots if wont idle..help plz
Poboy kartman
Senior Moments Member
White Settlement Texas
Whether it be 1 1/2 or 2 1/2 or whatever.....that's just a starting point....you need to adjust it while it's running...(you probably need to open it more....but it'll become apparent pretty quickly which way you need to go.)
tawas23
ok thank you for helping me.. do you know for sure the start point 2 1/2 or 1 1/2 on a klin carb
