150cc 5 speed engine - $150
Bwdeaton
Dayton, Ohio
Would like to sell this motor to someon who could put it to good use.
It is a 150cc Honda clone motor with an integrated 5 speed manual transmission. Has mounting plate capable design with a standard go kart motor type of mounting on the bottom also has mounts for lots of other applications.
Started and ran when I bought it. I didn't end up using it for my project. Was on a street go kart that jumped a curb going too fast and bent the frame. The engine includes all wiring to run and a carburetor. No exhaust pipe included.
Can send pictures.
Asking $150 for it, plus shipping if necessary.
Bwdeaton
Dayton, Ohio
Bwdeaton
Dayton, Ohio
It should make a fun kart or bike for someone who wants a manual transmission. Should be able to be geared for 55-60mph. This is not electric start, which is less convenient, but also saves some weight.
Some more specs.
-149cc displacement
-60lbs wet (with oil)
-9.5 to 1 compression ratio
-max engine RPM~ 9500
-approximately 12hp
-gear ratios
>primary reduction 3.333 to 1 (crank to clutch input)
>1st gear 2.769
>2nd gear 1.882
>3rd gear 1.400
>4th gear 1.095
>5th gear 0.923
Internal parts from 2003-2005 Honda crf150f engines are compatible. This is just a reverse engineered copy.
Bwdeaton
Dayton, Ohio
I cleaned it up a bit and started it today. It runs good, I took a short video. I'll try to upload the video later tonight.
Bwdeaton
Dayton, Ohio
I would ship from Dayton Ohio and will drop off at the shipping provider.
It is still available.
How tall from bottom to top.
Suppose I wanted to mount it on a minibike...
How much room would I need between a flat (parallel to the ground) mounting plate and the top bar??
I think I read like 18" or 19" but not sure if that was a 150cc or not.
Bwdeaton
Dayton, Ohio
Ill measure it when i get home for you.
---------- Post added at 04:31 PM ---------- Previous post was at 04:06 PM ----------
Measures just under 17 inches from bottom mount to top of head.
Bwdeaton
Dayton, Ohio
How much space is open above a predator 212 in a minibike frame like a baja or something similar? I read that a predator is 14" tall vs 17" so I could see it fitting in a minibike. It would be a neat bike too.
