13hp with torque converter problems
kamden5689
Oklahoma
I have a 13 hp engine with a torque converter. the chain kept making a weird noise, so I looked and the sprockets were not aligned, so I aligned them with a plum bob. and now the torque converter rubs the chain, and when the chain is off it will rub the sprocket. I really have no idea what to do. any ideas?
kamden5689
Oklahoma
Im just in a pickle lol. i have no idea what to do.
[/attach][/attach][/attach][/attach]
kamden5689
Oklahoma
in those pictures they are not aligned because the chain would rub the TC, the master link snapped off for the 5th time so i just left it off.
BigMark408
BigMark408
Portland, OR
i would add thin bearing ring/spacer behind the sprocket to push everything out evenly and keep your spacing. or try and adjust your jackshaft slightly left towards the TC side of engine by way of loosening that locking nut on the end to give you some extra clearance.
kamden5689
Oklahoma
how would I go about doing that?
---------- Post added at 05:36 PM ---------- Previous post was at 05:35 PM ----------
kamden5689
Oklahoma
yes. quite a few... so if I take off the bolt on the TC do
I have to torque get it back to specific pounds? these TC's are new to me.
that's the gopowersports series40 Kit, correct?
Not a fan of that concept, but the chain should indeed run free.
I even doubt it's a TC issue at all to be honest.
Do you happen to have one of those cheap laser levels at home?
(some recent home renovations and a $6 line laser to level pictures or tiles?)
Since my best guess is that your engine itself is slightly tilted to one side,
which in turn tilts the TC backplate slightly and of course the sprocket...
and that could cause the chain to rub .. either on the backplate or the driven itself.
It certainly looks tilted on the third pic.. but that can be caused by the camera;
so a laser level can verify it's right angle in regards to the axle sprocket, which is terribly hard to do with a bubble level and some straight edges and angles.
If you don't, then you can try the following,
adjust the axle sprocket to as close to ideal as possible inline with the TC sprocket (chain installed);
now loosen the engine bolts correct the alignment.
or -of course- go to your hardware store and buy one (you want a magnetic base and a 90° turnable lens.. should cost you no more than maybe 10 bucks .. I got mine off ebay for less than 6)
[EDIT]
quickly fake laserlined your second image...
see what I mean?
kamden5689
Oklahoma
lets say the motor is not leveled. could I just put two washers on the left side to level it? or is it a bit more complicated?
---------- Post added at 10:12 AM ---------- Previous post was at 10:05 AM ----------
I kinda like the washer idea, it seems simple enough, I really just want something that's gonna get me riding by 7 tonight. LOL. I bought this about a week ago, when I test rode it, nothing was wrong. NOTHING. it's driving me crazy! what could of happened in that week?!? I rode it for maybe an hour. my lord I'm so impatient I just want to get it going.
---------- Post added at 10:15 AM ---------- Previous post was at 10:12 AM ----------
and lol sorry, yes it is a 40series.
---------- Post added at 10:27 AM ---------- Previous post was at 10:15 AM ----------
okay so I used a plum bob, and it's definitely slanted. a friend of mine thinks the guy who build this did not square the mounting holes, but honestly I have no idea.
kamden5689
Oklahoma
so is there a easy fix to this?
---------- Post added at 12:26 PM ---------- Previous post was at 12:22 PM ----------
is this just one of those put the chain on, loosen the mounting bolts and adjust it like that type of deal? or is this more complicated?
Poboy kartman
Senior Moments Member
White Settlement Texas
[EDIT]
see what I mean?
UMMMMMMMMMMM......YEAH! WTF?
Do I need to quote this two more times before it sinks in?
