13hp blue clone won't idle below 57degrees
r1ng3l78
like the title says, if it's above 57 degrees F, it fires and runs fine. below that, it's start fine on full choke and idle for a couple minutes half choked but open the choke or give it any throttle and it starts to pulse, dies, and won't start again for about 15 minutes. i was going to adjust the mixture but the brass screw is broken. i'm going to start filing a groove in it to turn it until one of you kind fellows gives me some advice.
slideways
Is it brand new? Have you ever taken the carb apart on it? If its brand new and doesn't have old gas or anything like that wrong with it it may just need the low speed jet opened up slightly.
r1ng3l78
yeah it's brand new. it has a mixture adjustment and that's it. it was in the 60's today so i was using it to drag brush around the house.
anderkart
Surprise Arizona USA
Those are very bizarre symptoms.
Ok lets start out with a very basic fuel test first, follow my directions exactly:
The next time the engine its malfunctioning, immediately turn OFF your petcock/fuel flow valve.
and then unscrew the drain plug you'll find in your carbs float bowl.
The drain plug is not the bolt going upwards in the very center, its the other one that's screwed in on a diagonal angle.
(the drain plug is the 12mm. head-size bolt shown in the bottom-left corner of this pic)
All were trying to discover here in this test is if you had gas in your float bowl or not, when it was malfunctioning. So simply let us know if a couple ounce's of gas ran out of the float bowl or not ???
Once we know this for a fact, we can move on to other more advanced diagnostic tests.
