130292 5hp briggs and stratton engine wont start
Gokartguy04
Pickin junk is my thing
Colorado
Hello guys,
I have a question about my old go kart engine it is a 5 hp horizontal shaft briggs and Stratton engine with the model number of 130292. My question is why won't it start. I have cleaned the carb and cleaned the points and condenser and it has great spark now. It started a couple of days ago but now it won't. Oh and it does burn a little oil if that has anything to do with it. But any help would be great.
Just because you cleaned the carb doesn't mean it's working properly. Does it try to kick at all? Have you tried putting fuel through the spark plug hole to see if it will kick?
r_chez_08
Should be in the shop...
Cornwall, UK
If the engine starts and runs for a second or so on test fuel then your problem lies in your fuel system.
If not, then your problem is most likely elsewhere.
