13 horse conversion
14hp Predator? I've heard of a 13hp but not a 14hp...
IIRC Yerf Dogs come standard with around a 5hp engine & TAV2 CVT; to keep that setup, you need to either redrill or replace the engine mount plate & replace the TAV2 with a larger, more expensive 40 series CVT. Everything else shoud be the same...
What he said.
And I am not too sure if the larger engine would fit comfortably on the back of the kart ie. if there will be enough space. You are going to have to measure. You might have to realign the axle sprocket as well
kartbuilder1
florida
By looking at everything involved I also think I have to add some steel plate to the jackshaft plate to match the new motor mount plate
supermanotorious
Winchmaster 5000
New River, AZ
I frequently think about doing this to my yerf dog, I think with an aftermarket gas tank, header, and intake, you'll have plenty of clearance for the engine, as for the torque converter and engine mount, you'll definently have to re-configure
kartbuilder1
florida
I understand I will have to switch to a 40 series tc but the way the jackshaft mounts is the same as the motor mount. Do You see what I mean? I think I will have to modify them both
The comet 40 also does not come with a jackshaft, so yes, you will have to custon make something for the specific belt distance that the 40 series requires
