qtband
The key or the solenoid stuck on this kart when my daughter had it. She didn't know what to do so she did nothing until the starter stopped running. I took the starter apart and found that a magnet on the outside casing came unglued. I assume it was from heat. The other magnets are fine. The rest of the starter is good. Here's what I did...
I cleaned the magnet and removed most of the adhesive and left a little in place to help me center the magnet. I did the same to the casing. I used JB weld and a clamp to adhere the magnet.
Will this work or should I use some other adhesive?
