Can any body tell me how to adjust idle on this carburetor also there is a hose coming off bottom of carburetor not sure where it should connect nothing cones out of it the only place I can see it might go is pipe on top of carb.
The line on the bottom is just a float bowl drain. It get hooks to nothing. If you loosened the screw next to it gas would pour out. The idle speed screw should be on the other side.
