11hp grey hound motor?
webstertroy90
Im trading for a gocart tonight with a 11hp greyhound motor how are these? frame is a carter5 month old motor..... whats your opinion on these? how fast can they go on a 1 seat cart
ryf
gearing gearing gearing speed is rpm's HP is power. they all turn at about the same 3600 RPM assuming stock so they all go the same speed with the same gearing, :) need tire size, gear ratio's etc. to tell speed. you CAN go to a higher ratio to get higher speed with more power available :) not trying to be an pain, you just can't answer the question really. assuming the gearing is the same, your acceleration will be much improved though :)
