11hp briggs vertical shaft
exenos
Project Nut
Could any one tell me if this has a oil pump or a dipper? I'm in the process of converting it to a horizontal shaft for my mini bike.
sideways
Unfinished projects king.
Perth, Western Australia
You're going to have to open the cases up to mod it anyway, so crack them open and have a look! :thumbsup:
If you have the Model-Type-Code then we can probably help you.
Thanks
Hayden
exenos
Project Nut
When i go to the garage tomorrow i'll get the model code of of it. I already have the carbs remounted, so the oil dipper/pump is the only issue right now. Thanks for the quick responses.
Often (but not always) a pressure-lubricated engine (pump) will have an oil filter, whereas splash-lube engines never do. Does yours?
exenos
Project Nut
I went out and got the code and its 252707 0172-01 82012611. While i was out there i took of the crank case side and found that it has a oil dipper, not an oil pump.
