110cc emmick yamaha trouble
davidw2340
Hello, just purchased a couple emmick karts really cheap. I'm having trouble getting my 110cc emmick 2 stroke yamaha to hit. It has fire, good compression, and I know it's not a fuel delivery problem as I'm priming the motor manually through the carb/intake port.
The starter mechanism that came with the kart isn't working. The starter needs to be refreshened, brushes, cleaned up etc etc. My dad is going to go through it soon as time allows him to.
In the mean time I'm using a 1/2" drive Milwaukee drill with the adapter/extension that goes into the clutch, to try and make the motor hit a lick. Nothing.
What rpm do I have to be turning the motor over in order for it to be able to crank. I'm don't think the drill is turning fast enough to make the mag generate enough spark. Though it does infact have spark, I'm not sure it's enough.
starter insert and clutch:
kendelrk
redneck engineer
westland michigan
Does it sound like its gonna start or more like a slow pull of a lawn mower? If it sounds like its trying then put a small amount (i hear a teaspoon is recommended) of 2 stroke Down the plug hole and see if anything happens, to be safe put the rear two drive wheels in the air with a stand of some sort. If it sounds like the drill cant spin fast enough, is this a shifter cart? If so get some buddies to Aid you in a push start
davidw2340
Naw i can't get it to hit at all. I did already put a small amount of two stroke oil down the hole aswell. Already purged the system of any water, drained the tank, blew through the lines, filter etc.No sir it isn't a shifter kart.
I'm almost positive the drill isn't spinning fast enough to make the mag make enough spark.Atleast I hope this is the problem, else i'm lost haha. Have to wait for the starter to get rebuilt to find out I guess.
Thanks for the reply.Appreciate it.
regards,
david
anderkart
Surprise Arizona USA
I agree your drill most likely is not spinning fast enough rpm. I'm guessing my Burris racekart starters spin my engines up to like 1000 to 1500rpm... Your KT100 engines prolly need to spin at least 1000rpm to have a chance of starting. You need to get that kart starter fixed, or meybe its battery was just weak. Did you try connecting jumper cables to a good car battery?
davidw2340
Thankyou. The starter had sat outside in the alaskan weather for ~2 years. So it pretty much needed a rebuild. I did use 2 good batteries though during the initial test. I'm actually about to go pickup the rebuilt starter from my dads, apparently the brushes, armature etc etc were all rusted together.At any rate, bout to step out the door and go grab that! We'll see what happens.
Appreciate the response, makes me feel a little better in the meantime =P
davidw2340
Okay, so she's running like a top now. I just have one more silly question, this time pertaining to the horseman clutch. I've made sure the clutch has the correct amount of oil etc.I have the kart atop a stand. Whenever I fire the motor up, instead of acting like it has a clutch, it acts like it has direct drive instead.The wheels spin, it wont idle if the wheels are at a dead stop.
Now, to me this defeats the whole purpose of the clutch.Either the clutch is fried or... I just don't know how this particular clutch works. I've idled the motor down to an unreasonably low idle and the clutch stays engaged. Should I buy a new clutch or a clutch kit? Or does this particular clutch act similar to a direct drive setup? (silly question I know)
The reason I'm asking this silly of a question is because I watched a few emmick kt100 karts being fired up on youtube, and they all act the same way. Except I'm just not sure if the karts I watched are direct drive or not, as I couldn't get a very good look at the motor/clutch setup in the videos.
regards,
David
