10hp riding mower engine throttle reversed
gvfc2
wishing i was living
Tacoma,wa
i put the throttle on slow is revs really high i put it in fast abd it revs low. how can i fix this? its a tecumseh 10hp if need be ill get the model number
First, check the linkage. Take the air cleaner off, and watch the choke plate while moving the throttle lever. The choke should close at max throttle. (this is assuming the choke is controlled by the same lever). Now- is it here that the engine runs fast, or slow? What I'm getting at, is that it's possible somebody simply installed the handle upside down.
klicky96
Sandusky, Ohio
I agree with Toystory, either something is backwards or someone messed with the linkage and screwed it up. I don't see this being a carb issue. I see this being a linkage malfunction/issue.
gvfc2
Tacoma,wa
ok well ill have to check tomorrow. im trying to sell it so im trying to work out the kinks. but im also installing a throttle pedal instead of the stock throttle. because in order to engage cutting deck it has to be at max throttle or it dies.
