10hp briggs
Swabbster
i have an old genset it needs a coil i think, have not touched it in like a year or two, but looking online at how the crank looks it is usable for me, well i can get it machined to 1 inch with a key slot, it may be 1 inch not sure but there is a step that goes in the side cover but it is like 2 inches longer than it has to be, the crank looks like 6 -7 inches long so i could get it machined, but how long should it be for a comet 40 series? so now the story of the genset it self, my dad bought it like 4 -5 years ago, it got used little, it sat and lost spark, but it is not an old one with points, i think the coil went bad or the switch, i installed a new switch and i think it got spark, but then had carb issues and i did not have the tools to take the carb studs off so it has been in my back yard for about a year, id like to someday convert a dead electric golf cart to gas power and use the 10hp briggs, or build a mini baja like the buggy type thing, if i recall its from 97 i think, oh ya and the shroud mounting holes are cracked from vibrations, so i think i will cut and weld some sheet metal in im too cheap!
