10hp briggs pull start
trekkie28001
I just got a go kart with 10hp briggs. The pull start does not move the flywheel. It pulls and retracts too easy but will not catch. The flywheel will move fine when I turn the shaft. It will start and run fine when the pull rope is working.
trekkie28001
Idk what type recoil it is its a side shaft with differential and the pull start looks like the same on my push mower. It turns the shaft that supposed to catch the flywheel. If its like my mower it will be a ball bearing gear type but i havent taken it apart yet.
trekkie28001
It was the balls had stuck to the outside. I took them out and cleaned them and it works now. I posted a pick of it. If this happens to you just remember to check you balls.:thumbsup:
