10 hp vs 18 hp?
kartman2788
Hey all,
I need help deciding whether to use a 10 or 18 hp engine on my go kart? What are some pros and cons of both?
Thanks in advance,
Sam
B man
Tecumseh FTW!
Oliver springs,Tn
not really any difference. either way you have to get a TC 40 series. weight,but power balances that out.
edit: power would be better from the 18hp.
anderkart
Surprise Arizona USA
Given a choice, I'd certainly go with the 18hp with a 40-series torque converter.
The drawback would be additional weight, so you'd probably need additional bracing/gusset-ing to your frame and motor-mount area.
element10554
Glen Mills Pa
I have an 18hp with a 40 series and I feel like the engine is to much for the TC. If I am not careful when I hit the gas the belt starts to burn up. Just a thought.
redsox985
PA
Element, something is probably wrong, the 40 series can take up to 25HP according to Blaz.
The 40 series was factory rated to 18hp- you can bet your bottom that they would have left a pretty generous error margin in the rating. 25hp sounds reasonable.
redsox985
PA
I remember Blaz noting that they've had big twin cylinder karts in excess of 20HP working perfectly with a 40 series. Comet under shot the 40's potential but got the 20/30's just about spot on.
