10 hp Briggs and Stratton off a generator throttle issues
jmjbot
okay, for the issue: I have a 10 hp briggs and stratton off a generator. I have had issue trying to figure out how to make a manual throttle. I read this http://www.diygokarts.com/vb/showthread.php?t=9939 and i have the same linkage as in the pictures. I didnt not understand what the guy did. can anyone tell me step by step what to do so that i can set up the throttle because it is governed at one speed. thanks!
joshkidner
West Michigan
in the pic do you see the rectangle cut out of the plastic on the outside? mine has a lever there (made for log splitter to change idle.) i loosened the bolt that kept it tight and hooked a cable up to that. it looks harder for you and would likely be easier to not use the govener. if you want to use it then look for the part im talking about and install it. (its a briggs 900 series if you want to look it up)
