1" shaft
jim454
I have a 8 H.P. Tecumseh with a 1" shaft.I now have a custom belt drive system,but would like to put a clutch on the engine but it doesn't have any threads in the end of the crank. Has anyone drilled and tapped a 1" shaft with success.I am thinking of making a guide to drill and tap it out?Thanks:huh:
jim454
Russ where did you get that clutch?Is that a 3/4" shaft or a 1"
jim454
Thank's Rusty now I just have to save up for the clutch.My son is very happy!
jim454
Belt drive
$14.00 For a belt ,they usually last 1 season.
fowler
Bullsbrook West Aus
can i make a surgestion
it is recomended that the belt is tensioned inwards so if u make the tesioner come from the other side and make it push the belt in it basicaly means that there is more belt touching more pully at any one time and this will help belt slippage
jim454
There isn't any room on the other side .This is the only way this will work on this set-up.For now it is O.k..I only have the engine at 5/8 throttle and it really moves.I will get a clutch eventually.When this thing winds up it will go fast.I had to slow it down for the kid's
Bluethunder3320
Same idea as belt drive in a snowblower. If you hve ever looked under the cover its just like that. Pull the lever and the belt tensions.
One season though? My neighbors snowblower i use for them when theyre on vacation is at least 20 years old and im pretty sure its all original.
jim454
Did anyone ever sit on the snowblower when they were snowblowing the driveway?
