Yeah thanks chez
My used clutch is made for a 1-1/4" pto. The drum has a needle bearing that rides directly on the pto. The key in my clutch hub is permanently attached, not a separate key. So there's no easy way to fudge things and use it on a 1.125 output shaft.
Besides that, unfortunately this used clutch I have is also a
20-tooth/#35-chain model, so even if it fit your pto, you would still probably need a jackshaft to end up with some reasonable gearing...
Another more realistic solution you could consider here is: Just doing whatever machining necessary to simply mount a solid drive gear on the engines crank, and then locate a heavy-duty centrifugal clutch on a jackshafts output side... Like the pic at the bottom of this page illustrates.
To choose a centrifugal clutch model strong enough to survive, and gear tooth counts for everything:
You'd need to confirm the H/P of that engine,
and post the karts rear tire diameter,
and post the kart and driver (passengers?) approx weight.
and post what type of driving conditions the kart will be used for.
(like maybe all serious off-road/steep hill climbing in the sand/mud
or maybe all high speed cruising on large open/flat/hard packed terrain,
or paved streets/parking lots as an example)
Here's a link to a jackshaft gearing calculator:
http://www.compgoparts.com/TechnicalResources/JackshaftRatioCalculator.asp
Here's a search link to the 1" bore "Noram Star" race clutch model that I use on both of my racekarts and highly recommend:
http://www.google.com/search?q=Nora...osoft:en-us:IE-Address&ie=&oe=&rlz=1I7GZAZ_en
If you could turn his pto down to 1" and broach a keyway you could just mount a clutch on the engine and skip using a jackshaft.
Here's a pic of my Star clutch:
(its a big-ol heavy duty mutha !!!)
You wont find any publish max-H/P ratings for the Noram Star clutch model, but both of my Star clutches have survived my 20+H/P racekart engines for a couple years now with some very hard use. You'll also find a Bunch of guys over on a Mower-racer forum called "heymow.com" that use and recommend this very same clutch model with up to 45-H/P engines!!!
You would simply need to install a 1" diameter jackshaft with a 1/4" keyway and threaded bolt-hole in the end of the output side to use/retain a Star clutch. The Star clutch is available in your choice of 13 through 18 tooth models, but only comes in a #35 chain pitch. It can be mounted with its drive gear inboard or outboard.
If you will be running a #40/41 rear sprocket, the 1" bore Noram 1600-series model might be another option to consider:
http://www.google.com/search?source...&rlz=1T4GZAZ_enUS369US369&q=Noram+1600+clutch
