So I figured I mine as well start a new thread for this one since I have been all over the place in my posts. Currently realizing they also moved the brake master locating spot as well as the gas pedal linkage mounting spot. They also moved the pedal mounting spots which was dumb because they used pedal risers (maybe they moved them first and it didn’t work, idk) But I currently got it mostly taken apart and things cut out to reweld. The front end is definitely tweaked too, so I was going to take it to a chassis straightening place but in the end I normally get too deep into a project of my own that I can’t ever enjoy it. Going to try and bend it back until both front spindle mounting locations rest evenly and then going to use a self etching primer and some cheap paint or por15 instead of going with powder coating. I always want my stuff to be top notch but I can’t always afford it or my skill set doesn’t match my taste. I guess you could say champagne taste on a beer budget lol. My seat slides will be in today so I can measure and mount my pedal location which will be at least some progress in the right direction.
