engine question
anonymous
Ok I need an engine that haul preferrably around 500lbs as fast as possible, and preferrably under $800. Secondly how do you suggest I hook up the engine? (Should I just make a direct chain link from the engine to the rear axle?)
Used motorcycle, quad, or sled engine- source a whole machine for $800 or less, get extra goodies like brakes off of it. If it's a bike or quad, a straight chain run to the rear axle is fine. For a sled, use the CVT it came with.
KieranM
Doin It!!
Kilkenny, Ireland
a motorbike of quad engine. Most quads come with a reverse gearbox aswell as 3/4 foward. You can then make up a shifter handle, and you have an engine for a shifter kart.
WI_Chopper
full of ideas...
buy an old ford escort? lol, basically a go kart, though i've seen better go karts than escorts.
Speedfreak
Get an old golf cart. It'll haul 500 easily right after purchase without any work. And if you score one pretty cheap you have some money for a motor upgrade.
