Briggs 5hp Flathead
FlamingChicken
I'm trying to get this motor running for a friend. It will run if I drizzle gas down the carb, but it won't pick up the fuel from the tank. The only thing that I see is strange, is that it is missing that metal tube that goes from the carb to the engine. The carb side is 'capped' off, but the block side is wide open. Could this be the cause?
brendonv
Australia, Perth
Nah thats just a valve breather tube. Its capped off so you dont have a hole after your air filter otherwise it can suck in dirty air. (may be the reason it isnt working, jet blocked) Ur pickup tube is probably blocked. Take the tank of the carb, it thinks its with 3 screws and on the carb is two tubes. Clean them out with an air compressor. While your at it clean the tank. Put some bolts and nuts in there, some fuel and vigorously shake it. All the bolts with scrape all the rust out. Repeat about 3 times.
motor_head
expert garbage picker
sutherland IA
might be the diaphram, one of the bolt holes for the air cleaner goes down to the bowl fill that up and see if it runs for a bit
otherwise just clean out the carb
Blazkowiez
Kart Aficionado
Houston, Texas
You do have a clogged carb that needs to be cleaned, check your gaskets, jets etc... The very first thing anyone does when they want to make their engine run better is remove that EPA recycler tube. I am not in any way advocating that we remove their emissions improving innovations, it is something that many many people do when they want their engines to run better because then it sucks up less dirty air...
FlamingChicken
OK guys, pulled the carb and this is what it looks like:
What is the best method for cleaning these carbs?
FlamingChicken
I was thinking wire brush, but wasn't sure if it would be too abrasive. Didn't know if there were any tricks/special tools too use. I'll just see what I can do. Thanks for all of the help guys!
natman316
is that EPA recycler tube you talk about that tube that connects to the carb?
