Sleepy122CID
- Messages
- 110
- Reaction score
- 0
Just picked up a project kart on the low-low with a maybe kinda running (maybe not) GX160. When I went to look at it the guy started it with an electric drill. Today I realized that was because the recoil starter is falling apart (I can't get the screw to hold the assembly to the cover - it keeps backing out every time I pull the rope). When he started it, it would run for maybe 20 seconds or so before dying.
Today I cannot even get it to do that. First I pulled the spark plug and found it was incorrect. Installing the proper plug (properly gapped) did not help. I checked to make sure the spark is consistent, and it seems pretty strong. I remembered the seller telling me he put a new carburetor on it, so I figured I better check that next after seeing the kind of plug that was in it
. The float seems to be working properly. As I was pulling it off I realized the idle screw was maxed out. I continued removing it to check it out even though I guess the idle thing could be leaning the mixture too much. When I got the carb off I checked to make sure the intake valve was moving freely, and it appears it is.
Now, although I work on cars for a living, I am a youngster and have never even looked at a carburetor up close
. I found a hose barb with nothing on it, and I was wondering what it is if anyone knows. I guess this is a very simple carb, for there are no fuel adjustment screws?
Anyway, what is this exposed barb for? I haven't checked compression yet, so I'm not at a dead end yet with the diagnosis, but if you have any ideas I am open to suggestions... This is the first small engine I've really looked at.
(smaller barb on top)
Thanks
Thanks
