minibike
r_chez_08
Should be in the shop...
Cornwall, UK
im thinking of making a minibike from some of my old gokart parts, like clutch sprocket ect.
i was going to see if i could pick up a cheap briggs 5hp or similar, either running or has a small problem. this would help me learn more about engines, as i havent fixed an engine with a bigger problem than a recoil :) would a 5hp be ok, and what wheels do you suggest. i was thinking doodlebug design :) oh, and quite ghetto :)
SpyGuy
Hooligan
Tucson, Arizona
Doodlebug design, or just go nuts and build a chopper. Go-kart parts should work fine, if you have a wheel with a sprocket already on it.
r_chez_08
Cornwall, UK
i have a google sketchup design. i will post tomorrow, as i am going to bed now. i saw a cheapish briggs on ebay, but im letting it go. i preferably want a honda, cos my dad says briggs arent as good, and can be a **** to start. wat do u think (i dont want a "carb problemd" teccy!)
KieranM
Doin It!!
Kilkenny, Ireland
calculated it out for your self. what speed/power would you get from a gx100 pulling yourself and the bike. i say it would be enough
r_chez_08
Cornwall, UK
i was probably going to use the sprocket and clutch from my gokart, 16t-93t, but im not sure if the chain is long enough, so i might go for a crude direct drive setup, or make a simple clutch on a lathe? maybe not :) heres the pic. i no the tubing is massive:) i am now thinking could i make a manual clutch? or even belt drive?
KieranM
Doin It!!
Kilkenny, Ireland
if i dont use my sprocket and chain, what sprocket and chain pitch do u reccomend?
I always use the sprockets and chains from tecnobots (0.5inch) for anything over 2hp because smaller ones might have a risk of breaking. Judging from your last few threads though i dont think you like tecnobots products :biggrin5:
motor_head
expert garbage picker
sutherland IA
are you kidding!! briggs are great engines all mine are very easy to start sometime one pull if you pull all the way back. i don't have much experience with the new ones but the older ones can shure take a beating and still be very reliable
r_chez_08
Cornwall, UK
My dad may have just had a bad expierience then. I might use belt drive now with belt tensioner setup. No I don't like technobots as the sprockets are mild steel. Also they are not keyed and don't go in to many teeth
r_chez_08
Cornwall, UK
Okay I am still thinking of building this thing, as a mate from school may be selling me
2 engines non running for £10 about 3hp or something. If I can get
1 running I will probably build this, but I was
wondering where to find a suitable belt and pulleys?
Blazkowiez
Kart Aficionado
Houston, Texas
www.northerntool.com ...... If they don't have it, you don't need it .....
Northern is dropping the majority of their kart parts line, their prices are 50/50 on the good bad scale and their only bonus for beginners is the fact they have a liberal return policy in person.
I love looking around the stores and have nothing against them but they price things so oddly!
r_chez_08
Cornwall, UK
Should be getting engines this weekend. I don't know how much power they will have if I can get them going, but I hope more than 3hp. I am planning for this to be under £50, engine£10, belt £5. Pulleys, turn on a lathe. Maybe buy for the axle/wheel. Wheels £10-20. brakes ghetto scrub or minimoto £5. Steel £5-10. make everything else, like forks, tensioner etc. I have drawn a design and will post it soon.
