Torque Converter for an 18 HP Briggs?
Stratogeezer
Norcross, GA
Hey guys - I've got a Briggs twin 18HP motor with a 1" drive shaft - and I'm looking for a torque converter clutch that is rated for 18HP. See the pictures below - I've got the mounting plate and rear drive pulley already.
When I look on eBay, I can find a 1" shaft Comet that would fit - but it's only rated up to about 8HP I believe. I'd assume that would work for awhile, then wear out?
I've got to believe someone makes a torque converter clutch that is rated higher - after all they're used in golf carts, atvs, etc.
Any ideas? The Comet clutch pictured below is for a 3/4" shaft - FYI. The other two parts (mounting plate and drive pulley) should work if I can find the right torque clutch to swap with the one pictured).
Thanks!
Blazkowiez
Kart Aficionado
Houston, Texas
Comet makes a series 40/44 torque converter assembly, you'll need to buy both pieces. You will end up spending near 400 after shipping and be forced to make the jack-shaft from scratch. Its understandable. You will not be able to use your driven with a series 40 drive, they are not compatible.
Stratogeezer
Norcross, GA
I actually was able to buy the back plate, plus two different size drive pulleys. One is too small for sure - it fits a #35 chain (stamped model "20 P3"). It's the darker one seen on the lower part of this photo.
The second one is for a larger chain size (stamped model "20 P4"). The P4 size is the one pictured on the top of this photo, mounted to the backing plate. Assuming the larger one works - I'm hoping to just find the clutch part to buy - and use the other 2 pieces I've got?
Thanks again!
Kaptain Krunch
Pro Junk Collector
vermont
The secondary you have might just be a 30 series too. You really need the 40/44 series for that engine, and mixing 30 series components with 40/44 wont work. If your going to have to spend more than $200 on a torque converter, its more worth it to just buy a bike engine IMO, much better than that twin, and comes with gearbox and manual clutch.
