set back
which one should i build?
  • side winder/ buggy
    Votes: 11 42.3%
  • awd road kart
    Votes: 4 15.4%
  • drag kart
    Votes: 0 0.0%
  • mini sand rail
    Votes: 11 42.3%
  • Total voters
    26
  • Poll closed .
Kaptain Krunch
Pro Junk Collector
vermont
kaptian be quite im tryna put money in your pocket.... lmao
doesnt really matter if it does i want it for experimental purposes
I can get you pictures, but when i went to get it i noticed a few parts are off it (spring and cover plate) and its really dirty. If i can find the piece u can have it for $5+ shipping, shipping might be a lot tho, u could prolly get a good one for just a little more on ebay... If it explodes its not my fault haha.
U definitely want those carbs? i cleaned, and soda blasted one, and i can definitely get the second one together, just wanted to make sure first.
I can get pictures of those later too, and if you interested in that driven.
I have a few brake rotors too, one splined bore, and one 11" with a metric bolt pattern.
Kaptain Krunch
Pro Junk Collector
vermont
So, here are the pictures. I measured the carbs to make sure they were 38s (was almost positive), and im pretty sure they are but i only have an american tape measure, it measures somewhere in between 1 1/2 and 1 7/16, ill barrow a caliper tomorrow and double check. Couldnt find the other brake rotor, was prolly useless since it was splined though. That one there is off a kawasaki motorcycle, 11" in diameter, some metric bolt pattern, and over 1/4" thick, must be 5/16 or so
Kaptain Krunch
Pro Junk Collector
vermont
So, couldnt say for the carbs since there not both cleaned yet and one is apart. But i got the rotor and secondary out, and they should ship for 14.50, or 13.49 and take twice as long. So for those two, i'd do 40 shipped? Then once i clean the other carb, i can get a shipping quote on those, can prolly do that tomorrow. If i can find the other parts for the driver, i can probably fit the carbs and that in one box, might be cheaper than shipping separately.
I can ship the driven and rotor tuesday most likely, maybe the carbs too. Let me know if that sounds good.
Kaptain Krunch
Pro Junk Collector
vermont
Im pretty sure one huge box would cost more, ill check though.
Oh wow it is a lot cheaper to ship it in one box, i should be able to ship it all for about $18.
I'll try to find the rest of that driver tomorrow, and clean the other carb then let you know.
I would do 70 shipped for everything if shipping does end up being $18 if that sounds good to you?
Rotore
Teh SPIK
Caguas, Puerto Rico
Finally made up my mind
Ima make a drag bike!
i have a design in mind but still need to lay it out. any idea on materials.
square tubing vs round
what size
anything
