What Mods
Rotore
Teh SPIK
Caguas, Puerto Rico
LIST YOUR MODS
everyone list your mods that you have done to your engine and your hp.
Mine makes 56hp @ 6700rpm room for improvement but i need to fine tune the carb.-
MODS:
*CAM (.505" lift 277-283 duration)
*1.6 rocker arm ratio
*Double valve springs- 125# seat pressure 260# open (.600").
*28hp Connecting rod
*copper head gasket
*bored factory carb.
*Command Zoomie Pipe Kit(exhaust) 1 1/4pipes
COMING SOON*
*Kohler Command Aluminum Valve Covers
*V-Twin Command Intake Manifold Setup for MSC Plenum
*Push Rod Guide Plates
*Command Billet Rods
*3.071 flat top JE pistons
*Titanium valves (stock length)
*Still need carb setup mikuni what size?
Kaptain Krunch
Pro Junk Collector
vermont
No clue what size mikuni you need, but i have 3 38mm mikunis, i could probably make 1 good carb minus choke and throttle cable out of them. If thats too big (might be), i also have a 32 or 34mm mikuni.
My engine is 400cc inline twin. Mods are:
custom high flow exhaust (home made, SS)
Uni Pod filters
making around 40hp
My Tecumseh Star motors have extensive porting, race pistons/cranks/rods/cams, Methanol Tollottson carbs, 3-stage headers and externally mounted block brace-plates to help hold everything together.
I'm well into my second race season with my old Star motor and just swapped a KT100 for another used one I'm freshening up to have around as my spare.
modelengineer
Lord of the noise
Sydney, Australia
Lol, I can just copy Kaptain's description and change the numers:
My engine is 500cc inline twin. Mods are:
Uni Pod filters
making around 55hp
Rotore
Teh SPIK
Caguas, Puerto Rico
