Engine with no spark .need help
Sail8870
Manco
Russ, I remember reading a thread about clones and you said you had one you hated and wanted to get rid off it, how bout a trade?
Sail8870
Manco
Ok, I may try to get a refund on that pull start, I pulled it 5 times and the metal wing things that catch the flywheel broke, then I may keep trying with getting it started, I'm not sure though
solomon
ca
Hey Russ, I'm rebuilding a 5HP Tecumseh right now, i would trade it for your clone when I'm done.
sideways
Unfinished projects king.
Perth, Western Australia
I'd definately be returning that. Also, this might sound silly, but how's your pull--start etiquette? A lot of people mangle thier recoil assemblies because they just grab the handle and go for the glory! Folks, you're not trying to uproot a tree! Grasp the handle and gently pull toward you. Let the mechanism grab the crank, keep gently pulling until you feel the compression stroke. Then, give it a firm tug to start the engine. Your recoil assembly will love you forever, and your arm will probably be a lot happier, too!
solomon
ca
YUP, never had to do this before, but once i overhauled my 8hp briggs, thier was soo much compression that you had no choice but to slowly pull it to compression stroke or else you were just going to break the rope and your arm, lol. This method works wonders!
Sail8870
Manco
Yeah, my brother yanked it without letting it catch, so if I can't get a refund he's gonna be paying for it.
starterwds
new york
i have the same engine on a go kart i got... i took it off and got the clone from harbor freight but I'm trying to fix it too and i have compression/spark and fuel but it wont start also... weird... but I took it apart and cleaned everything and am putting it back together... try checking the valves and check the specs to see what the installed height should be... I'm looking to get mine running soon and sell it if your interested russ2251... I can take pics and show you what I have... its just missing the recoil starter and air filter cover but that is coming in soon I ordered it from a local shop
