Thanks, Anderkart! I was wondering that myself... I knew that a functioning alternator added a load to the engine, but I had no idea how much, nor did I know that the load was proportinal to demand. I wonder how that works- Is the magnetic field actually that difficult to overcome? And-
Could you put the alternator on a switch (likely requiring a relay/solenoid) to de able to bypass it and get full horsepower when you want?
Your right, at higher output levels the rotor is spinning in a higher magnetic field.
Most of these 10SI alternators have Self Energizing Voltage regulators and will keep charging even if unplugged. You could try installing a super heavy-duty switch (or relay system) in-line into the alternators rear output post, but the internal voltage level would spike and that might end up damaging the Alternator.
Something you could try for free here is to take your Alternator apart, (just remove the 4 little 5/16" through bolts/the Stator stays with the rear half) and somehow cut/tap into
either of the brush's wire leeds, and then reconnect them through a toggle switch. Cutting the signal to either brush would stop the Alternator from charging and not damage anything.
FYI:
When your ready to reassemble the alternator, theres a little trick you'll need to know about... You'll find the brush holder has a very small hole you can poke a (straightened-out) paper clip through to hold the brushes back away from where they normally ride against the rotors slip rings. Slide your paper clip in from the from the small matching hole in the alts. rear case , then instal the Alternators back half, and simply pull the paper clip out to relese the brushes.
You'll find you can reinstall the Alternators back half in your choice of 4 different positions. Just select any clock/position that gets the wiring connections located where you want them.
All you'd need to do for wiring this up is conect the Alternators rear (Bat) post to your battery + post with 10 gauge wire. And then where the 2-wire plug goes in, just jumper/connect the Alternators 2 male plug conectors together. Most of these 10SI alts will work this way to make it an easy 1-wire instalation.
