10Hp tecumseh Cherry Red MUFFLER!
solomon
ca
well i tried another muffler and it actually ran worse. Plug looks very lean
Linksep
Twin Cities, Minnesota
Ok, you said doing a valve job more than doubled the compression... This makes me think the exhaust valve was burned before and this isn't a new problem. You also just said the plug looks very lean...
When you rebuilt the carb did you replace the float needle and seat? Did you make sure to properly adjust the float height?
Did you inspect the jet? Maybe it has a burr in it partially clogging it. I might replace the jet just for kicks, or find out how much a new carb assembly is. You might have a casting or machining defect somewhere in your carb that's restricting fuel flow.
I see you're in CA... Is there any place you can buy non-oxygenated gas there? Ethanol dilutes gas and makes you run lean. If you can find some non-oxy try that. If the muffler is no longer glowing with non-oxy you know it's a carburetor/jetting issue.
solomon
ca
yea, i rebuilt the whole thing, and even let it soak for 2 days in the heavy duty carb cleaning solvent in a can similar to a paint can. One thing i should mention is this engine had a huge exhaust on it when i got it, and now i think i know why. It has several pipe fittings to make it all work. this motor must just be garbage. I don't understand because this motor is the same engine as the other i pulled the exhaust from. I couldn't install the motor on the generator with the huge exhaust. What do you guys think? Junk?
Kaptain Krunch
Pro Junk Collector
vermont
you just need to re-jet. Its runnin lean thats all.
But for the record i do think its junk because its a tecumseh.
solomon
ca
i have always hated Tecumseh, which holes do i drill on the main jet? there are 2 on each side of the jet and 1 in the middle. thanks
Linksep
The one in the middle. Did you shove a stiff wire down the jet to clear it of debris or burs? Alternatively you can spray carb-cleaner backwards through the jet (in the center hole, out the side holes) to make sure it's clear. Wear goggles though, the carb cleaner will spray in every direction. The two (large) side holes pick up fuel from the bowl and the (small) center hole meters the fuel into the intake air flow.
And where's those pics you promised us?
solomon
ca
well i took some pics but have yet to figure out how to upload =p its been a while
Kaptain Krunch
Pro Junk Collector
vermont
Have you checked to make sure none of the cooling fins are clogged up? Other than that take the carb apart and make sure the jets arent clogged, could it possibly be the wrong carb for the engine?
solomon
ca
well maybe it was for the other block. IDK, guess so, so im just gonna have to drill it?
Linksep
What's the model # and serial #? They should both be stamped on the blower housing and read something like HH70 or HM100 (Model #) and something like 8105c for the serial #... If they're not stamped on the blower housing look for an ID tag bolted to the head or a sticker somewhere with similar info. I'll try to post up a pic of the carb so you can verify it's the right one.
solomon
ca
Its an HM100
Awhile back, someone here posted they'd ran into problems after accidentally installing their Tecumseh float bowl clocked in the wrong position... Seems like it was a bit smaller Tec. model than yours but it might be worth double checking.
Linksep
Possibly. If the float can't drop all the way down there might not be the proper amount of fuel in the bowl, which can lead to improper (lean) mixture.
Tecumseh Technician's Handbook said:
Make sure the deepest end of the bowl is
opposite of the inlet needle.
