wierd output shaft
kohler321
diesel enthusiast
Cereal, AB
I just purchased a 6hp yanmar diesel clone for 125 dollars. It is from a generator, and has great compression, but there is one problem i see with it. The output shaft has no key-way. It has a little bit of taper at the beginning then goes like a regular output shaft until it is about flush with the engine. Why would there be no key-way, and would it be possible to get a machine shop to put one in?
Also, i will post a pic tomorrow hopefully.
Thanks.
Russ2251
AZUSA:Powered by LAWN-BOY
...has great compression...
Necessary, as this is source of ignition.
...output shaft has no key-way...
...a little bit of taper...
Keyway not needed for generator and is typical of most (all?) generator engines. Taper is necessary for fitment of alternator rotor to pto. Nothing weird about it. Unusable "as is" for anything other than what they are designed for.
Yup, but may be cheaper to get an engine with correct pto.
I was quoted $250 (varies) to get a keyway cut and requires removal of crankshaft.
You will still have the taper to deal with.
Expense cannot justify the use of a generator engine.
mike75925
thinker and tinkerer
Alto, tx
i could see charging 250 if they were using a file. i know i wouldn't want to do it.
Kaptain Krunch
Pro Junk Collector
vermont
$250 is a HUGE rip off, i could toss a crank in the mill, and cut a keyway in it in 20 minutes easily (if not less).
Are there any tech schools around you? i know my shop will often fix, or make parts for people for very cheap or free.
kohler321
diesel enthusiast
Cereal, AB
Thanks for the replies, i will call around for the cost of getting a key-way installed. here are some pics by the way...
Dougthewelder
if you want to do it cheap you can use an angle grinder or dremel to cut a keyway.
im so cheep i was thinking the same thing, then i read your post lol.
the whole time im thinking to myself *hmm i bet if i had the right sized cutting wheel on my angle grinder i could put a usable key way on that shaft* :idea2:
kohler321
diesel enthusiast
Cereal, AB
ya, i was kind of thinking that, but the margin of error is small, and once i screw up, i cant try again. If prices are to costly, or i have to remove the crank, i will either make a longer taper pulley, or try that angle grinder technique.
Russ2251
This was done by hand. Shaft diameter is 63/64". Keyway is ¼ x ⅛.
