Thunderbird SC
I have a few different small two cycle engine to choose from for my gas powered Gaucho. The Gaucho is a symmetrical torque converter system 20 series driving a 6 inch driven. The the 10t sprocket #35 chain and a 54t sprocket. The wheel's diameter is 13.5 inches and the finished kart weight is maybe 80lbs max so far.
I have the following engines 75, 85 and (3)98cc Tecumseh piston ports and a 102cc Briggs piston port. I hope to get a better less worn 102c BS one for cheap.
Lets start with the Tecumseh engines. The flywheel is light and features a straight fan blade design, measures 6.5 inches in diameter. The ports on this engine are designed for easy and cheap manufacturing which involves drilling 3 overlaping holes like that of an audi logo (intake).The transfer ports are long in length from the crank and are not formed in any way other than straight drill paths. The crankcase volume is rather large which I believe would lead to weaker vacuum/ pressure pulses. The intake mounts on an angle causing a bend in airflow and the exhaust is on the side of the engine which lands very close to the TC and requires routing the exhaust pipe through the belt
. I can say this engine revs very quickly and is a hard one to idle at low rpm. There are lots of thin deep cooling fins which would lead me to think that this one is suited for summer use as well. In closing this engine fully assembled with carb and housing weighs a whopping 9 lbs!!
