Hi , I think your gonna be similar to my rear setup , lol , I just got all my shocks yesterday , I`m gonna be using some front forks on the rear also , I`m going to use a Jackshaft , have the ends turned down to 3/4" , then put one of these on each end with a high grade bolt through it and the jackshaft to keep it all together , will use a short 6" axle on the other end for the wheel hub , using pillow blocks on it , I will have to shorten the center section of these steering shafts for the right length , theres a U-Joint on both ends , the center sections are also a slip joint fit to extend or compress , the shafts are off a 1991 Jeep Cherokee , theres 2 different ones used in the Cherokee`s , Aluminum end ones and steel end ones , the steel end ones have a 3/4" hole in the yokes , the Aluminum end ones have a 5/8" hole in the yokes , these are about $ 135 average for one , but in the wrecking yards they can be had Cheap , here in my Pull It Yard I can get 2 of them for # 30.00 , its what I`m going to use , I do only have a 185cc Trike engine though , I still think they should hold up to your engine ,, Bill
