Manual tranny?????
kartermicah
Washingtonish
how would i put a motorcycle transmission on a go kart?????? and if i did i definitely want a stick shifter that would be sick. tell me is that even possible
Kaptain Krunch
Pro Junk Collector
vermont
You would have to put the whole engine on. Its possible, i have done and many others here have too. Its not too hard, but its no slap and go project. You need some basic fabrication skills, a welder, and some other basic metal working tools.
Most all Harley's have separate trannys except the Sportster/older dirt bike models. Most Harley trannys conect to the engine with either a multi-row type primary chain or cogged belt that drives the clutch basket, thats connected to the trannys input shaft. The trannys made for the old 3-wheeled Harley Servicars had a reverse gear feature that would be kinda cool on a kart.
Separate transmissions was a very common feature of most all realy old motorcycle brands including (pre-unit) Triumph/Norton/BSA's.
Kaptain Krunch
Pro Junk Collector
vermont
Ok, so you could just use the tranny, but i would opt for the whole engine anyways, a big tranny connected to a clone would be kind of lame.
