35chain vs. 41
1992suburban
I wanna go FAST!!
Sanford, NC
well my Hilliard clutch is showing some wear, the driver teeth are REAL SHARP.. so I am thiinking about buyin a 41chain clutch sprocket setup.
I play hard on my kart and she takes a beating!! offroad, onroad, and ROCK QUARRY trips....
have not had any trouble with chain breaking but the links get REAL stiff!!
granted I am only runnin the cheap $1-2 a foot stuff would I be better of sticking with the 35 and buyin like some GOODCHAIN DID GOLD???
what do you guys think
modelengineer
Lord of the noise
Sydney, Australia
Do you clean and lubricate the chain each time you use it? If not then no chain will last long, and the sprockets wear really quickly too.
If that's not the problem, then I'd go to #41 just because it should solve all problems and last longer than the #35
Kaptain Krunch
Pro Junk Collector
vermont
I personally dont like #35 because it has no rollers, if you can afford it i would definitely go for #41.
NapO
Canada
how do you like your hillard clutch? i wasthinking of getting one for my off road kart
Kaptain Krunch
Pro Junk Collector
vermont
All my #35 chain is roller chain.
How?
Roller chain is made in several sizes, the most common American National Standards Institute (ANSI0 standards being 40, 50, 60, and 80. The first digit(s) indicate the pitch of the chain in eighths of an inch, with the last digit being 0 for standard chain, 1 for lightweight chain, and 5 for bushed chain with no rollers.
(wikipedia)
1992suburban
I wanna go FAST!!
Sanford, NC
I like it I have had it since August. and now the teeth are worn on the sprocket but thats the only wear it shows grabs good.. NO COMPLAINTS I am rough on the kart too..
donuts, gravel, sand, pavement, ect ect ect and it carries me @ 250lbs and my daughter shes 30-40lbs JUST fine
Kaptain Krunch
Pro Junk Collector
vermont
Link didn't work Russ, I have never seen #35 chain with rollers. Can you take some specific pictures of your chain? And maybe PM meso we don't hijack this thread too bad.
The Product
Willow Beach, Ontario
yea i have the #35 roller chain from princess auto
lol you were scaring me for a minute, i thought it was roller chain cuz the it looked like it and the sign said so. i would of bin a bit mad if princess auto jipped me haha
I feel using cheap quality chain, running wore out sprockets, misalignment/masterlink issues and failing to properly clean/lubricate is the only reason most guys ever have any trouble running #35 chains. Although I admit a 40/41 sized chain of equal quality would probably be more tolerant of misuse.
