My Kohler overhaul
Rotore
Teh SPIK
Caguas, Puerto Rico
Well guys it had to rebuild the kohler since it was literally poop.
But i got it stripped down cleaned the block, ordered a new piston, cleaned the head and got a replacement for one since at was also poop, cut the seats, lapped the valves and will get the crank down tommarow hopefully.
I found a replacement piston for it but the original was 3.266 and the replacement is 3.277 and had a chip so i ordered a new one.
Rotore
Teh SPIK
Caguas, Puerto Rico
more piks
more piks
Rotore
Teh SPIK
Caguas, Puerto Rico
Wsup!!!!!!!!!!
Well i didnt clean the crank since i was freaking out about the pistons. So i went wire wheel crazy on the pistons and measured bore and piston and labeled them.
Also ball honed the cylinders so its smooooooothh.
here are the measurements:
*piston 1: 3.267
*piston 2: 3.267
Bore
cyl. 1: 3.268
cyl. 2: 3.269
But i have a question in the shop manual it sayd the std. bore size for it is 3.270 my bore is under that by .001 and .002 is this normal?
Kaptain Krunch
Pro Junk Collector
vermont
If anything the bore should be over what the manual says from wear, did you measure it in a few places to make sure?
Kaptain Krunch
Pro Junk Collector
vermont
nope i just followed the manual 10mm from the top and 10mm from the bottom of the bore. maybe its me screwing up ill measure it again on monday to be sure.
Yup, measure it again, although .002 isn't that much. Im not sure what the tolerance is, it may be .002 for the cylinders, and this one just happened to be on the low side.
