Score!!!!!!!!!!
Rotore
Teh SPIK
Caguas, Puerto Rico
just got a 725cc 25hp horz. Kohler for free! Guess you guys were right about waiting.
But all i kno from a visual opp. is that its a 725cc, pressure lub w/ oil cooler twin cyl. w/ an electric start.
time for an over powered gokart dont you think...? No i got to get it running i expect it has a broken connecting rod and leaking exhaust valves.
I'll post piks and model type code later on.
Rotore
Teh SPIK
Caguas, Puerto Rico
Do you have a link where I can find one?
Do you mean for axle clutches? If so, just google "go kart clutch" and include your axles diameter. (They'd just need to be the type that mount with set-screws or maybe you could even use lock collars to secure some other types). Most any brand new clutch that can handle 25hp is gonna be exspencive. The least exspencive option might be finding a suitable/ used 3/4" bore race clutch and mounting it on a jackshaft. If your running a 1" axle, there's several 1" bore race clutch models sold that could handle your engine
motor_head
expert garbage picker
sutherland IA
a little high for the big tires but for the small tires might want it alittle higher
big tire-48mph
small tire-25mph
