What # chain do you guys use?
Freakly
Ok so i got my tires/rims (13/5/6) and now im just wondering about the #(35 or 41) chain clutch to get. There are alot of #35 sprockets (with alot of teeth selection and such) but not alot of #41. A guy are work keeps telling me to go with #41 chain so i dont break it. But other say use a #35 cause it wont matter. So another thing to figure out :confused:. But im intrested in what you guys/gals are using on your setup and how good/bad they work. Thanks :D
Freakly
HF Clone 6.5. Now if i was to get a #41 sprocket what is the biggest size i can get? I can only find 60t on kart shops.
I've ran a quality brand of #35 (RLV Xtreme gold on gold) in a methanol powered 357cc./20hp dirt oval race kart and havent had any chain problems at all. With that said, if your running an even higher powered engine or meyby have a heavy off road type kart, the stronger #41 size might be a better choice for you.
Freakly
its just going to be a yard cart no big bumbs or nothing just grass/gravel and pavement
ps anderkart i saw that topic with the videos of the dirt oval track you raced at and that caught my interest alot. I would love to be able to do that around here but there are no tracks(well to my knowledge) around me.
1992suburban
I wanna go FAST!!
Sanford, NC
I have had no issues with my 35 chain
but my brother EXACT SAME SETUP has ruined his clutch (teeth) and broke the chain.
Freakly
Thanks for the links :), I was thinking along the line of a 62 or 64 tooth. Bmi karts has a nice soild #41/60t from a yerf dog that looks promising ;)
Yeah just make sure your engine/sprockets are all perfectly lined up and you'll be fine with either size chain. I like #35 cause quality sprockets are easy to find in any size and usualy cost much less.
You might ask around, meyby there's a track somewhere you dont know about. I didnt know my track existed until I posted a craigslist ad seeking other people that wanted to ride/race karts. I had 2 diferent dudes respond and turn me on to the track.
t0x1k
Vroom
South, NJ
#420, I'll never use anything less in the 40 line of chain, it snaps too easily.
I kept breaking chains even when I wasn't using a master link.
I really would like to upgrade to 520, but I need to get my hands on a motorcycle engine.
mike75925
thinker and tinkerer
Alto, tx
basically, the bigger the chain the longer it will last. there are of course those smaller chains that have the same strength as a size or two larger, but you definitely see it in the price of the chain. ander, you had 360ccs and only 20hp? must've been a 'small engine'. dirt bikes from 50-125cc or so run 420/428; street bikes 250-750cc run 520/530/630; higher hps run higher strength chain. for 100 links of good bike chain you can spend anywhere from 50-250 dollars. a common trick is to run 520 on a bigger bike to save weight and power. the heavier chains will help wear out your clutch quicker, but can aid in torque (off idle). i run 40/41 on my kart, but i would see about getting an o-ring chain (35 or 40/41), they are far better on bikes, and i would run one on my kart given the choice.
Freakly
Thanks for all the posts guys. Im thinking about using a quality #35 chain so that i can get a better ratio like kenny said. But we will figure it out when the pay check comes lol ;)
