Go kart pics
mikeandike
i got the pics... i had some trouble with the motor mounting and the bearings. The motor alignment was all out of whack so i redrilled them and the bearings had to be moved back to tighten the chain so i redrilled that too then my dad realised that we could have put shims in between the bearings and the frame to tighten it...
mikeandike
More pics...
mikeandike
Even more pics...
I had to lower the quality of some of the pics so they would uplaod
RobertD
Administrator
Texas
ncie work! for the engine mounting, there's no plate -- is that coming later, or did you drill through the frame?
mikeandike
i drilled through the frame... my frame is aluminum so it was pretty forgiving for the screwed up engine mounting holes
I used nylocks on all the bolt i put in so they wont vibrate out. For those of you who dont know what nylocks are theyre a nut with a small nylon ring at the end theyre very annoying if u have to thread them on a long bolt sticking out but THEY WONT COME LOOSE WITHOUT A WRENCH :)
RobertD
Administrator
Texas
just worried since you won't have any way to adjust the tension of the chain...
mat1
did you get your stuff from princess auto??? ant is that a 7/8'' axel
mikeandike
will aluminun C brackets for the spindles be strong enough to hold up a go kart? because i'm either going to weld an aluminum front on or make a steel front that slides into the existing frame and bolt it on
