Where do you get an engine from?
r_chez_08
Should be in the shop...
Cornwall, UK
depends what for. motorbike engines are good for full suspention karts/ shifter karts.
the junkyard may have something.
over 5hp is best. 6.5hp clone from harbour freight is good, for about $100 with coupons.
I've found great deals on my local craigslist.
Just make sure its got a standard style output shaft with a keyway slot and a threaded hole at the end like this pic: http://www.colinjamespoulter.co.uk/mediac/400_0/media/DIR_105267/New~engine~for~kart.jpg
And NOT a tapered shaft like this pic: http://www.tamarisktechnicals.co.uk/images/kart/engine1.jpg
Most guys here have ended up using either 5 or 6.5 hp engines but you can prety much use any size engine your kart has room for. Larger sized engines over 6.5 hp can sometimes weigh a lot more so you need to consider that too.
(once you get up to the 8 hp and over range, they usualy require a 1" shaft size clutch or torque converter. These cost more than the 3/4" clutches that smaller kart engines use)
johnnyKart
So is something like this what I need to be looking for (from craigslist):
"BS 5 HP Industrial Horizontal Motor (BEARING not BUSHING) Bronze Chemical Pump"
just under $100
That might be fine but it doesnt say what kind of output shaft it has. You'll need to ask the dude about that or check it out in person. Lots of used engines sold on craigslist came off pressure washer pumps and generators, some (but not all) of these have the tapered style shafts that you cant easly mount a regular go kart clutch on.
johnnyKart
What kind of output shaft do I look for? I know you said a longer one. I am asking if it has a formal name like the shaft orientation does (horizontal, vertical).
johnnyKart
Are the harbor freight, all clones, okay? I ask because I have read threads elsewhere that named them as lifan, central machinery, and others. Right now I saw "greyhound" as the maker. Just try it and see I guess.
Here's what I found:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66015
another one:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66014
The formal name would probably be a "straight keyed shaft".
I never said anything about a longer one, If you carefully look at the 2 link pics I posted above, the one on top is a straight keyed shaft. Its flat all the way across and has a threaded hole at the end. (this is what you want)
The 2nd pic I linked shows a shaft that tapers to a smaller size near the end. (you dont want one of these)
I dont know if Greyhound is any better than the rest, but lots of guys have had great luck with all those diferent brands of Honda clone motors. I've read that many guys that race clones prefer the yellow painted brand. (what ever that is)
1992suburban
I wanna go FAST!!
Sanford, NC
if I may..
greyhound seems to be a pretty good one I have personally talked with several engine builders; ARC Stout Racing NR Racing and they told me they are just as good as any color.. The yellows are chosen based off of the findings that they are VERY Close to each other. example. some BLUE clones pistons are "in the hole" more or less then others. Valve covers change, different carbs.. RuXing VS Hauyai ect ect
Just buy whats cheap you can get the yellow for 99bux from ARC and the blue from HF for the same depending on if you use a coupon.
Kenny_McCormic
Kartless....
Michigan Troll
I got my engine from my dad's logsplitter, we swapped in a freaking huge one(some unknown iron block Briggs), at idle the splitter now almost hops up and down.
johnnyKart
if I may..
sorry to be dumb...what is ARC?
ApocGoD
Deus Ex Machina
Florida, Starke
I can attest to that. I have a perkins 13.7Hp diesel on my mud buggy and it weights 180lbs.
