Celerity Quicksilver Sport Coupe (EA racer)
Roll over protection
When I flipped (rolled) the body over
...the top edge of the body kinda buckled a bit
It bounced right back
...& didn't seem to damage anything
but
Brought roll over protection back "in to my mind"
When designing this racer, I figured on using a centrally located 1" steel tube roll bar
...kinda like the 2 x 4 wooden roll bar, mocked-up, in this pic
The drivers head would/should be in that "little pocket" right under & behind the roll bar
...& it should help protect the driver from side impacts too
Plenty of room on each side of the seat
...looks ta be (~6 1/2")
Wow! that's a lot
...maybe too much room??
Now, I'ma thinkin' about...maybe...some kind of engineered composite roll bar
...or maybe even a hy-bred (metal, FG & structural foam) roll bar
Anyone ever seen or heard of such a thing??
Roll bars are made of steel for a reason. I wouldn’t want to be a vegetable because I got lazy or cheap.
Me neither
...but, I'ma always thinkin' (floatin' around in free thought)
...& then, drawin' them ideas (here in the real world) ;)
So, early one morning, this idea/concept started off...something like this
Then, I got ta thinkin'...maybe with a thin-walled steel tube
...embedded inside some structural foam (as a skeleton)
Then "floated" in another direction :innocent:
...& thought about an engineered "T" Bar type "thingy" :thumbsup:
With an engineered panel supporting/bracing an engineered panel
...& then, capped with some thin-walled steel (Abrasion "Road Rash" Protection)
Then, kinda "put dem concepts together"
...& this "appeared" :sifone:
I did some more drawin's
...to "note" & help explain, where I'm coming from :cheers2:
Seems like a standard steel tube roll bar, would just be bolted to the floorboard, with some kinda flange
...but, it would be basically/only secured to the entire racer, by (2) little flanges (1 on each side)
Then, we could add a couple of rear braces
...to the main roll bar
...but, they would basically/only be secured, to the entire racer, by (2) little flanges (1 on each side) too
It seems like having the roll bar(s) embedded, in the structure
...would secure/adhere 'em all of the way around
...& along the entire length, of the roll bars ;)
* Which should tremendously increase the "Roll Over Systems" mounting strength, to the monocoque
...& the materials themselves should help brace, support & enhance each other :thumbsup:
If a rear brace is added-in-the-mix
...the overall strength of the racer should increase...even more :2guns:
This is what I have had "in mind" for the Power Package :thumbsup:
A curved steel tube
...mounted in between (& to) the (2) engineered panel "spines"
...that the rear wheel
...& the motor mounts to
* The battery pack will probably be mounted in between the "spines"
...& to the back side of the seat panel too
Ideas evolve...as new info...comes in :thumbsup:
Now, I can "see" that "if" the rear roll bar brace bar(s) were extending down
...to "be" that thin steel tube, that the rear wheel & motor mounts to
This concept would provide a nice-n-straight "Load Path" from the rear wheel
...all of the way up to the top of the roll over protection system
...which should "spread the load", from the rear wheel, across the entire rear of the monocoque :2guns:
Hey Denny,
On most race cars the roll bars/cage is an installed afterthought
...but, "what if" the roll over protection system was incorporated into the entire chassis/body? :unsure:
Like, if the "bars" went thru the A-pillars, instead of next to them
...it seems like, the A-pillars would help support the bars
...just as much as the bars, would support the A-pillars :thumbsup:
Now, if we extend that "carry the load" from the rear wheel, up to the top of the roll over protection concept, to the front 🤓
It should also "spread the load", from the front wheel(s) all of the way up to the top of the roll over protection system
...& across the entire front of the monocoque too ;)
Then, in the overall "big picture" the entire roll over protection system should act like a "skeleton" supporting the entire FG monocoque
...from the inside, against most any load that is/can be applied :2guns:
Roll bars are NEVER an afterthought nor are cages. Even in street cars they are taken into consideration when building a car. They provide much more than just crash protection. They are there to stiffen the chassis up or to allow limited flex. What ever the car may need.
Hey Denny,
A bit intense...maybe a little too much caffeine...there my friend :innocent:
Check out these 10" x 2 1/2" Aluminum wheels
...with built in hubs
...&/also, has rotor (or sprocket) mounts too
Tires too
FYI: 10" x 2 1/2" rims take either 14 x 2.50 tires (or 2.50-10)
...so, it seems that the tire for a 10" x 2 1/2" rim, is ~14" overall (hence 14 x 2.50)
...very confusing o_O
They have nice low rolling resistance tread pattern
...a J speed rating (up to 62 MPH)
...directional arrows
...& even kool little Tiger Paws, on the tread :thumbsup:
The bearings, in the hubs, on them wheels are for use with 12mm spindles
...so, I "rounded up" some spindles that will work with bearings with a 12mm center hole
Wow! They even have bearings, that they pivot on
* Notice (1) of the Loc-Nuts is missin'?
It's no big deal as we need to use Castle Nuts, with retaining pins
...but, it's still gone o_O
They look like this, with a wheel (& Rotor) mounted on 'em
They have a decent lookin' mounting bracket too
I ordered (2) Rotors
...& received (2) Rotors
...but, um...??? :huh:
* They even have the same part number??? :mad2:
Maybe gonna order (2) more
...& hope for "matchin" ones to arrive :ROFLMAO:
Ride height w/wheel(s) mock up
* It's sittin' pretty much level
...just resting on 2-2x4's in the front & rear (~3")
Another view
Again...thinkin' about undercar aero
...what if we "lifted" the front a bit?
* Which would let more air up/in/under the car
...that should/will get compressed (a bit) under the lowest area (potentially creating a lower pressure area)
...& then, get "sucked" up & out the back, of the racer, thru/past that big 'ol diffuser :thumbsup:
** We could even install side "skirts" (on the rear) to create aero tunnels ;)
Currently sittin' ~1" higher, in the front
I'ma thinkin' about makin' the front (& maybe rear) ride height...adjustable
...so/then, I can "try out" different "set ups" :sifone:
What would "lifting the front a bit" help?
...as the undercar aero didn't seem to do much, on the Granite racer o_O
Well, I've been thinkin' about it a bit more (always thinkin') 🤓
So, now, I'm thinkin' the "size" (or volume) of the low-pressure area/zone, affects how much low pressure is or can be created
...& the "low pressure creation areas or zones" under the Granite racer, were only ~4" wide x ~2"tall, on each side (or x2)
...& the rear diffusers, are only ~8" wide x 8" tall (also x 2)
Whereas on this racer, "low pressure creation area/zone" could be/is, the entire width of the floor
...which is ~27" wide
...& the diffuser, is also the entire width of the racer (minus the width of the rear tire) ~16" tall at the "exit"
I'ma gonna try-n-make this racer go faster :auto:
...maybe up in the 40's :2guns:
