Mudhead 208r with Predator 420cc belt hitting disc brake
Smogs
Hello!
I just picked up a 2021 mudhead 208r with a Predator 420cc conversion done. It has a 40 series torque converter. The disc brake is cutting into the belt. What’s the best solution for this? Does the torque converter appear to be installed correctly?
Also, what size/brand tires should I put on to boost speed? Currently has 16 x 6-8 up front and 16 x 7-8 on rear. In MN so snow, grass, dirt for driving. I’m new to all of this and want to show the kids a good time 😁
OneTimeUser
We Don't Rent Pigs
Texas
Me too! I just found the same cart yesterday and bought it home. It has been sitting for a long time and is rusty an such but is completely stock and unmolested. Tires are not worn at all and the belt cover appears to have never been removed.
Please tell us how the 420 fits and handles and co exists with the transmission. I may make that swap.
Here are a couple of pictures of mine coming home in the trailer.
Staff Murderator
I’m surprised, frankly, that the brake disc is right under the TC. Maybe you and OneTimeUser can show us what clearance is available to move the disc and caliper over or the TC.
Smogs
I’ve removed the belt so hopefully this gives you a better idea.
Staff Murderator
Raise the engine up, add more links to the drive chain...?
Does the kart appear to have been modified or ‘messed with’ by the pervious owner? They’re 95% hacks and just want to get their karts running again, no matter the cost.
Smogs
The previous owner’s family member had made the conversion. Changed the back to put a plate to hold the 420cc predator motor, 40 series torque converter, air filter, and a bigger battery (58 group).
Hard to believe it was designed like that. I would look at the chain tensioning system and see why the engine is so low.
Smogs
Get a longer bolt to tip the engine forward to raise it up and add some chain lengths to accommodate? Picture below. Thanks for everyone’s help!
